> From: Steve Kale <stevekale@btinternet.com>
> Date: Sun, 20 Nov 2005 22:31:08 +0000
> Conversation: [Digital BW] Re: Comparison: K3 versus Ultrachrome inks on
> Semi-Matte + ImagePri
> Subject: Re: [Digital BW] Re: Comparison: K3 versus Ultrachrome inks on
> No Clayton you completely missed my point and a lack of technical knowledge
> is clearly getting in the way of your comprehension. Focus and perhaps
> learn something - if only about what I did and did not say.
> I merely said that often people make judgements about print settings by
> printing a step wedge, measuring the numbers (or just looking at the
> printout) and seeing that "there is not good separation" between 95 patch
> and the 100 patch. What I was saying was "don't forget that there isn't
> intended to be good separation between 95K and 100K in the GG 2.2 space."
> They are meant to be very close. This is simply fact and defined by the
> nature of the space. So if Epson has modelled their default "darker"
> setting such that it gave an optimal transform of a GG2.2 workspace to their
> printer then a step wedge printed through Adv B&W would show those patches
> as being very close together (and the 90K patch not far behind). That's a
> good thing.
> If your image looks good in GG2.2 you have there ensured the shadow detail
> you desire, visually - you have made it such that the pixel values are not
> too close together in the shadows (so-to-speak). You might have set one
> area to be 85% K because 90% K is too dark in GG 2.2. It is here that you
> should be ensuring that your "shadows aren't blocked up". From there you
> simply care about the best possible rendition of that in the narrower print
> space. You would want that printer to put 95K very close to 100K with 90K
> not far behind because that is what you have in your image file. If the
> printer did something different then it's doing you a disservice by
> over-opening the shadows more than you intended. We have had some
> interesting conversations very recently on this forum that have been
> complete misled by a lack of understanding of this point.
> Once again, a GG2.2-tagged step wedge printed in a colour managed workflow
> will show a 95 patch that is very close to 100 and a 90 patch that isn't far
> behind 95. Adv B&W is not a colour managed workflow but as we have recently
> discussed, there is reason to believe that Epson has modelled Adv B&W's
> default response on a GG2.2 space. This is speculation but the bunching of
> the K steps at the darker end of the scale is consistent with a 2.2 gamma
> space. Epson could have just had the Adv B&W response be extremely linear.
> Or they could have said to themselves "well most people use Adobe RGB and so
> why don't we model Adv B&W's default behaviour such that it produces a 2.2
> gamma-like response because after-all it's not a colour-managed workflow and
> we don't do it then the user will have to do some arbitrary print s-curve
> for decent output." In the latter case, if we printed a step wedge through
> Adv B&W's default setting then we would see the 95% K patch being printed
> very close to the 100% K etc etc.
> The other point I made was another SIMPLE one. You're better off making
> tonal adjustments in a sophisticated image editor like Photoshop rather than
> with a simple printer driver.
> Couple these two things together and of course you can do whatever you want
> and I don't care. But I would suggest and did say that IF Epson has
> modelled the default Adv B&W response on a GG 2.2/Adobe RGB space then it
> makes sense to edit in that space (if you are not already doing so), print
> with the default settings and use a sophisticated image editor to ensure you
> have visually pleasing tonal separation. This can be improved further by
> profiling the Adv B&W settings with an ICC profile such as that generated by
> QTR Create ICC so that you have a good soft proof to work with. I do the
> latter and it works extremely well. And yes, if I print a step wedge
> through this workflow the 95 patch is printed very close to the 100 patch -
> RIGHT WHERE IT SHOULD BE.
>> From: Clayton Jones <cj@...>
>> Date: Sun, 20 Nov 2005 19:12:16 -0000
>> Subject: [Digital BW] Re: Comparison: K3 versus Ultrachrome inks on
>> Semi-Matte
>> + ImagePri
>> Hello Steve,
>>> People get hung up printing step wedges and looking at the 90K and
>>> 95K vs 100K patches...in GG2.2 there is NOT meant to be a big
>>> difference at all between 95K and 100K and only a small difference
>>> between 90K and 100K...people often...complain that the shadows are
>>> "blocked up" because they note that the 95K patch is not
>>> significantly separated from the 100K patch...GG2.2 says they are
>>> meant to be bunched at the ends.
>> So according to what you are saying, photographers who now do digital
>> printing aren't supposed to bring their personal aesthetic judgments
>> to the work any more. Instead we're supposed to plug in the numbers
>> and accept what comes out because someone somwhere decided that GG2.2
>> is what we're supposed to use and that dark values are supposed to be
>> bunched up. Hogwash! If people "complain that the shadows are
>> blocked up" it's probably because the ARE blocked up (and not because
>> they see it in a wedge - they see it in their prints). It just so
>> happens that, aside from ink/paper permanance issues and printer
>> clogs, blocked up shadows in prints has been the primary problem that
>> people have been struggling with for the last several years. It's
>> been a universal complaint.
>> I do not consider myself to be "hung up" because I (and countless
>> others) prefer good shadow separation. A step wedge is the best way
>> to see _why_ something in a print looks the way it does. I don't care
>> what someone in a laboratory somewhere decided should be the ideal
>> ramp. I know what I like in my prints, which is based on over 20
>> years darkroom experience, and I strive to get it in the most
>> efficient manner I can.
>> It is an observable fact that the "Light" setting produces the most
>> well separated dark zones and the darker settings compress them. When
>> the darker settings are used, it forces us to compensate for the
>> compression with our image adjustment curves or profiles or whatever
>> method is used, which often means greater manipulation of the original
>> image. I've found that the more manipulation I do the greater chance
>> of negatively affecting the final result (combed histogram, etc). In
>> my experience the "Light" setting produces the best prints while
>> requiring less work and manipulation.
>> If something is "meant to be bunched at the ends" then no thanks, you
>> can have it. I've been working for years NOT to have blocked up
>> shadow zones. Please refrain from labeling someone as "hung up" who
>> doesn't subscribe to all your theories and numbers.
>> Regards,
>> Clayton
>> Info on black and white digital printing at
>> http://www.cjcom.net/digiprnarts.htm
>> Please visit the Group Homepage to check the Files, and other resources as
>> they are often being updated.
>> http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint
>> If you wish to receive no emails or just a daily digest, or you wish to
>> unsubscribe, please edit your Membership preferences by visiting this same
>> page.
>> Please follow these basic guidelines:
>> - As threads develop, trim off excess portions of earlier messages to keep
>> them short.
>> - Good manners are required at all time. No personal attacks or flames.
>> Hostile, aggressive or argumentative users may be removed from the membership
>> without notice.
>> - Keep your posts and threads related to the group topic of digital B&W
>> printing. Users who persistently make off-topic posts may be removed from the
>> membership.
>> - By posting on this forum you agree to abide by the group rules and
>> guidelines, and to abide by the actions and decisions of the group Owner and
>> Moderators. See ³Group Topic, Rules and Guidelines² in the Files section:
>> http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint/files/
>> BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW, THE PRINT
>> YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE ³OWNER² AND
>> ³MODERATORS² OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO YOU
>> FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL OR EXEMPLARY
>> DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS OF PROFITS, GOODWILL,
>> USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE ³OWNER² AND ³MODERATORS²
>> OF
>> DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF
>> SUCH
>> DAMAGES), RESULTING FROM: (i) THE USE OR THE INABILITY TO USE THE DIGITAL BW,
>> THE PRINT YAHOO GROUP; (ii) UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR
>> TRANSMISSIONS OR DATA; (iii) STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE
>> DIGITAL BW, THE PRINT YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE
>> DIGITAL BW, THE PRINT YAHOO GROUP.
>> Yahoo! Groups Links
> page.
> them short.
> without notice.
> membership.
> Moderators. See “Group Topic, Rules and Guidelines” in the Files section:
> YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE “OWNER” AND
> “MODERATORS” OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE LIABLE TO YOU
> USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF THE “OWNER” AND “MODERATORS” OF
> DIGITAL BW, THE PRINT YAHOO GROUP HAVE BEEN ADVISED OF THE POSSIBILITY OF SUCH
