Paul,
The data section of the test file is in nine colums as follows: Data
number (1-51 in my case, 1-21 in yours); Sample name (A1, A2, A3, B1,
B2, B3, C1, etc.); percentage of gray (e.g. 80.00); XYZ_X (e.g.
4.65); XYZ_Y (e.g. 4.77); XYZ_Z (e.g. 3.54); LAB_L (26.08); LAB_A
(e.g. 0.58); LAB_B (e.g. 2.52).
Roy or Steve would know better, but I doubt Create ICC is reading the
first column and probably not the second. As Steve also suggested,
the LAB_A and LAB_B columns could also be filled with zeros if you do
not want to soft proof the actual paper color. As the column
headings are misalighed in my text file, I don't think Create ICC is
looking for these headings, but rather columnar data that makes
sense, left to right. So, don't worry about the headings. I suspect
that columns 3-9 (or maybe 4-9) are the ones to have "in form."
I have found that the profiles from ICC create in a PS workflow are
incredibly useful and I would encourage you to at least take a
serious look at this. I have finally found a reliable, consistent
workflow to print through the Epson ABW driver. This should be the
same for any other form of output, driver, etc.
Best,
Walt
<paul.roark@v...> wrote:
> Walt,
> Thanks for the information, that clarifies it somewhat.
> I have an X-Rite where I'll have to create the text file manually.
What
> format is used? I see what appear to be some sample files in the
i1 folder,
> but it's not really clear how I'd plug in the L values for the 21
steps.
> Since I only have the 2.3.1, I may have to just wait until that
version is
> fixed.
> Paul
> www.PaulRoark.com
> > From: DigitalBlackandWhiteThePrint@yahoogroups.com
> > [mailto:DigitalBlackandWhiteThePrint@yahoogroups.com] On Behalf
Of wwodets
> > Sent: Monday, October 17, 2005 7:04 PM
> > To: DigitalBlackandWhiteThePrint@yahoogroups.com
> > Subject: Re: [Digital BW] ICC v. Transfer Function in Epson driver
> > Paul,
> > To try and clarify: The Create ICC.exe is a "droplet" program.
You
> > take the text file with the data and drag and drop it onto the
> > program (and not a shortcut to the program). Create ICC will then
> > create the ICC profile in the same folder as the text file. When
you
> > do this, a window will open momentarily while the program is
creating
> > the ICC profile, but the program does not "run." I keep a copy
of
> > the program on my desktop (not a shortcut to the program) and then
> > drag and drop the text file on it. I then have the ICC profiles
on
> > the desktop and move them to the color folder.
> > There is a text file in the Eye One folder of the QTR folder and
it
> > explains the use of the program. Although Steve has described
> > something different, I had problems with the output (to the
printer)
> > with Create ICC 2.3.1, so I have returned to the version in QTR
> > 2.3.0. In a post on the QTR forum, Roy actually suggested using
> > 2.3.0 for output until he corrected the problems in 2.3.1.
> > Best,
> > Walt
> > > Carl,
> > > Are you using Windows XP? I think one problem I'm having is
that
> > the Create
> > > ICC program doesn't seem to want to run at all. I assume this
is a
> > > different program than the Create Curve program -- or am I
totally
> > confused?
> > > Paul
> > > www.PaulRoark.com
Behalf
> > Of Carl
> > > > Schofield
> > > > Sent: Monday, October 17, 2005 5:02 PM
driver
> > > > Paul,
> > > > A simple text file with a column of Lab L values or density
values
> > > > measured from a 21 step wedge is probably all you need (use a
> > column
> > > > heading of D for density values or L for Lab L values). Just
drag
> > > > and drop the text file onto the Create-icc script and it
should
> > > > create both the icc profile and a text file with a plot of the
> > data.
> > > > Carl
> > > > On Oct 17, 2005, at 8:42 PM, Paul Roark wrote:
> > > > > Steve,
> > > > >>> So, does black point compensation mean the curve hits
(0,0)?
> > > > >> Yes. ...
> > > > > OK, BPC is used to take care of the end point issues, as I
> > > > > understand it.
> > > > >> ... in XYZ (for B&W we only care about Y)
> > > > > I thought Y in CIE XYZ was green. Or do you mean the Y in
xyY?
> > > > >> BPC scales the data such that the curve begins at 0,0.
> > > > >> So when you send pixel value 0 to the printer
> > > > >> it gets left at 0 and hence prints as dark as the printer
> > possibly
> > > > >> can.
> > > > > This is what I'd want.
> > > > >>> Is the QTR Curve Creator Linearization tab a look-up take
> > interface?
> > > > >> Now it is.
> > > > > I think I'm only able to open the Curves Creator and not the
> > > > > "QTR-Create-ICC.exe." Is this just a Mac program, or does
it
> > > > > require i1?
> > > > > (It's in the i1 folder.)
> > > > >> ... [Roy's] aim is to proof hue and luminance correctly.
> > > > > Ultimately, that could be useful, but for the B&W I'm
targeting
> > now
> > > > > it's
> > > > > complexity that gets in the way of the basics of B&W
printing.
> > > > >> ... ICC profiles have the advantage
> > > > >> that people can set up soft proof in the normal fashion.
> > > > > That sounds like another complex story. If we're in PS the
> > custom
> > > > > dot gain
> > > > > curves do it, but we do need to get a simpler method.
> > > > >>> Is there a place that describes the specific ways in
which a
> > > > >>> Windows XP user
> > > > >>> can use QTR to make an ICC that can be used in the Print
with
> > > > >>> Preview
> > > > >>> workflow and then the Epson driver?
> > > > >> Not sure but it is really very easy. Print a step wedge
with
> > the
> > > > >> workflow
> > > > >> of your choice eg Epson Adv B&W with a particular set of
> > > > >> settings. Scan
> > > > >> the
> > > > >> step wedge with an EyeOne or other device that will
provide the
> > > > >> sort of
> > > > >> data
> > > > >> QTR Create ICC can read. ...
> > > > > I'm not sure I can even open Create ICC. So far I just get
a
> > > > > momentary
> > > > > flash on the monitor.
> > > > >>> Are those ICCs useable in the Print with Preview procedure
> > > > >>> with the Epson driver?
> > > > >> Yes I use them all the time. I have profiled my Epson
Adv
> > B&W
> > > > >> settings, one for each hue - neutral, warm, sepia and
cool. I
> > do
> > > > >> not mess
> > > > >> with the darker and other settings (other than hue). I
prefer
> > to
> > > > >> edit the
> > > > >> image in PS rather than in the driver which has limited
editing
> > > > >> ability.
> > > > > The possible advantage with using the driver controls as
much as
> > > > > possible is
> > > > > that they may well be doing hardware linearization in the
> > driver --
> > > > > with no
> > > > > loss of grayscale steps. The ICC or TF in the Print with
> > Preview
> > > > > -- or
> > > > > anywhere in PS -- loses some information with each
> > transformation.
> > > > > Interesting stuff, but I don't seem to have an easy way to
make
> > the
> > > > > ICCs at
> > > > > this point.
> > > > > Paul
> > > > > www.PaulRoark.com
> > > > [Non-text portions of this message have been removed]
> > > > Please visit the Group Homepage to check the Files, and other
> > resources as
> > > > they are often being updated.
> > > > http://groups.yahoo.com/group/DigitalBlackandWhiteThePrint
> > > > If you wish to receive no emails or just a daily digest, or
you
> > wish to
> > > > unsubscribe, please edit your Membership preferences by
visiting
> > this same
> > > > page.
> > > > Please follow these basic guidelines:
> > > > - As threads develop, trim off excess portions of earlier
> > messages to keep
> > > > them short.
> > > > - Good manners are required at all time. No personal attacks
or
> > flames.
> > > > Hostile, aggressive or argumentative users may be removed
from the
> > > > membership without notice.
> > > > - Keep your posts and threads related to the group topic of
> > digital B&W
> > > > printing. Users who persistently make off-topic posts may be
> > removed from
> > > > the membership.
> > > > - By posting on this forum you agree to abide by the group
rules
> > and
> > > > guidelines, and to abide by the actions and decisions of the
> > group Owner
> > > > and Moderators. See Group Topic, Rules and Guidelines in the
> > Files
> > > > section:
> > > > BY PARTICIPATING IN AND/OR POSTING MESSAGES TO THE DIGITAL BW,
> > THE PRINT
> > > > YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE
OWNER
> > AND
> > > > MODERATORS OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE
> > LIABLE TO
> > > > YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
CONSEQUENTIAL
> > OR
> > > > EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR
LOSS
> > OF
> > > > PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN
IF
> > THE
> > > > OWNER AND MODERATORS OF DIGITAL BW, THE PRINT YAHOO GROUP
> > HAVE BEEN
> > > > ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM:
(i)
> > THE USE
> > > > OR THE INABILITY TO USE THE DIGITAL BW, THE PRINT YAHOO GROUP;
> > (ii)
> > > > UNAUTHORIZED ACCESS TO OR ALTERATION OF YOUR TRANSMISSIONS OR
> > DATA; (iii)
> > > > STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW,
THE
> > PRINT
> > > > YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL
BW,
> > THE
> > > > PRINT YAHOO GROUP.
> > > > Yahoo! Groups Links
resources as
> > If you wish to receive no emails or just a daily digest, or you
wish to
> > unsubscribe, please edit your Membership preferences by visiting
this same
> > page.
messages to keep
> > them short.
> > - Good manners are required at all time. No personal attacks or
flames.
> > Hostile, aggressive or argumentative users may be removed from the
digital B&W
removed from
> > the membership.
> > - By posting on this forum you agree to abide by the group rules
and
group Owner
> > and Moderators. See "Group Topic, Rules and Guidelines" in the
Files
> > section:
THE PRINT
> > YAHOO! GROUP YOU EXPRESSLY UNDERSTAND AND AGREE THAT THE "OWNER"
AND
> > "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP SHALL NOT BE
LIABLE TO
> > YOU FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, CONSEQUENTIAL
OR
> > EXEMPLARY DAMAGES, INCLUDING BUT NOT LIMITED TO, DAMAGES FOR LOSS
OF
> > PROFITS, GOODWILL, USE, DATA OR OTHER INTANGIBLE LOSSES (EVEN IF
THE
> > "OWNER" AND "MODERATORS" OF DIGITAL BW, THE PRINT YAHOO GROUP
HAVE BEEN
> > ADVISED OF THE POSSIBILITY OF SUCH DAMAGES), RESULTING FROM: (i)
THE USE
(ii)
DATA; (iii)
> > STATEMENTS OR CONDUCT OF ANY THIRD PARTY ON THE DIGITAL BW, THE
PRINT
> > YAHOO GROUP; OR (iv) ANY OTHER MATTER RELATING TO THE DIGITAL BW,
THE
> > PRINT YAHOO GROUP.
> > Yahoo! Groups Links
